questor42
Posted: Wed Oct 31, 2007 8:34 pm Post subject: RCA F36669 need help with parts |
Hi I have a RCA model F36669 chasis # CTC203ca9
The hot is a dead short 2SC5148 not a big deal but it also took out Q14101
and R14108 so bad that I cant read them, Q14101 has a hole burned through
it and even burned through the metal retaining clip, I have never seen that before.
R14108 looks like it was torched by Q14101
Can any one tell me the transistor part # and resistor ohm size or color code
Thanks for any help you can give me with this |
Posted: Wed Oct 31, 2007 10:18 pm Post subject: |
| Q14401 #244223, check R14107 43ohm., replace Q14401 #237470 hot, check Q14102 Nte159, check the fuse, R14108 .1ohm. |
questor42
Posted: Thu Nov 01, 2007 2:05 pm Post subject: RCA F36669 need help with parts |
From minnie
PostPosted: Wed Oct 31, 2007 10:18 pm Post subject: Reply with quote
Thanks for the reply, it seems all the problems were caused by coil, L14401
the only thing holding it on the board was the glue, removed-cleaned and resolderd.
I had a Q14401 2sc5148 to replace the shorted hot and will check the others you listed, But I need to know is R14108 .1ohm a carbon or wire wound resistor and what is Q14101
Thanks for your help |
Posted: Thu Nov 01, 2007 7:38 pm Post subject: |
| Q14101 STK2250. R14108 carbon. Search Q14101 by the rca part #. |
questor42
Posted: Fri Nov 02, 2007 2:42 pm Post subject: |
Are you sure about Q1410 being a STK2250 ? my Q14101 is a three leg transistor.
Thanks |
Posted: Fri Nov 02, 2007 10:54 pm Post subject: |
| Q14101 #244223. Sorry. |
