Matt B Guest
Posted: Thu Nov 23, 2006 8:49 am Post subject: HP monitor (HP L 1702) no power |
Hi
I have a HP L1702 monitor that will not turn on !! The Led turns green then nothing. I have removed the outer casing to have a look at the components and contacts, but i am not sure what i am looking at. Are there any basics i should check before i bin it ??
Thanks |
howdiedoodie Guest
Posted: Thu Feb 01, 2007 3:39 pm Post subject: hp1702 |
| The whole hp 1702 and l1955 monitors just do not last. I have had HP swap them out approximtely 37 times. It is under replacement warantee for 3 years Keep on swapping. |
se2000 Guest
Posted: Fri Mar 28, 2008 7:44 pm Post subject: case |
| Remove the black screws on the back. Pry around perimeter until separate. 3 screws for switch pcb, 4 screws around cage |
vinman62 Guest
Posted: Sun May 04, 2008 6:37 am Post subject: f1702 repair |
| resolder the 8 joints on the 4 yellow coils ,theyre cold solder joints usually fix problem[/b] |
vinman62 Guest
Posted: Sun May 04, 2008 6:46 am Post subject: f1702 repair |
| if you need more info let me know i'll post a link, |
rage Guest
Posted: Sun May 18, 2008 3:02 pm Post subject: |
| Hi do you think you could post that link please vinman. I'm having the same problem with an hp 1702 not powering up (not even leds.) I've opened the case but capacitors look fine and having trouble spotting cold solder joints. |
Y20-0093-1 1130 Statistical System Syste • guildline9340datasheet . Various • Panel HYDIS HV121WX6-111 0 [DS] . Variou • Комсомольская правда-1 Riso • hfe rq-v520 service en panasonic • BIRD 80AS1 Termaline Coaxial Load Resist • linn majik wakonda amplifier 1995 LINN • preamp DUMBLE • GA22-7070-1 4300 Processors PrincOps ECP • TC-P42X1, TC-P50X1, TC-P42S1, TC-P46S1, •
