Posted: Wed May 07, 2008 2:43 am Post subject: Vizio l32 makes high pitch noise then off then repeats |
i have repaired several lcd tvs now and this is the first one i have seen do this.
when you plug it in the light (yellow maybe? green?) comes on for a second and then off, while this is happening there is a very high pitch squeal coming from the back that seems to increase in pitch, then when the light goes dark the sound goes away.
and then it starts all over again and continues until you unplug it.
i have cracked the case on it and looked through the power and control board . i only see one issue on the power supply, the large 450v 150pf cap is just barely extended, have not discharged the cap yet to see if it holds charge or not.
need help on this one, it is for a friend who is way down on their luck and really needs some good fortune
thanks in advance
[email protected] |
Posted: Wed May 07, 2008 8:23 am Post subject: |
It sounds like the power supply is tripping for some reason. Either a fault in the PSU itself or a short circuit/overload on any of the output voltages.
Check for shorted rectifier diodes on the secondary side and also check for shorted filter caps. Try running the PSU with the load disconnected and suitable load resistors instead.
If there is a current sense resistor somewhere on the primary side (typically in series with the emitter/source of the switching transistor), make sure that it hasn't changed value. Also check out any snubber networks (R/C/diode) across the switching transistor or transformer primary. |
lg w2242t LG • 2sk1724 Sanyo • KCJ14F90 LG • 42LB2DE LG • ntmfs4852n ON Semiconductor • z-l720 ez k 209 AIWA • psmn7r0-60ys Philips • mitsubushi hsmt18 MITSUBISHI • tc-l32x5x ch.km15 tc-l32x5l tc-l32x5h ch • AWG790_Ver853779053000 whirlpool •
