skips1969
Posted: Wed May 16, 2007 12:42 pm Post subject: RCA TV turns off after 5-10 minutes |
It is turning itself off after 5-10 minutes of use. Can be re-started, but same thing continues. It's probably a 25" set, manufactured in June 1998, and is model# F25211BC. Was wondering if there was a common part going bad that would cause this and deciding if cost worthy to repair, or just replace.
Thanks |
Frank Guest
Posted: Thu May 17, 2007 7:06 pm Post subject: |
| What Chassis#? |
cory Guest
Posted: Thu May 17, 2007 11:01 pm Post subject: |
| check solder connections on verticsl ic,horizontal drive transformer and if it has it l14401 in horizontal circuit. |
Posted: Tue May 22, 2007 12:19 pm Post subject: |
So, there wouldn't be a common switch or something "plug-n-play" that goes out on these (frequently) that needs replaced? I haven't opened it up yet to clean and check soldered connections, was just curious if this was common on older TV's, RCA's in general, etc....
Thanks |
Posted: Fri Jun 15, 2007 12:36 am Post subject: |
| Chassis is CTC 185. Comon problem on this chassis are bad solder joints on L4401. It is located between Q4401 and T4301. |
Posted: Fri Jun 15, 2007 4:15 am Post subject: |
| Anonymous wrote: |
L14401 |
jijaju
Posted: Fri Jun 15, 2007 5:17 am Post subject: service manual for zenith/pvr6069dt |
| im working on this rear projection tv,the problem is it has a pin cushion on the top and the bottom of the screen,the convergence is mis align and i cant enter the service mode because there's no character so i cant even open the menu. |
brianjagielski
Posted: Sun Jun 17, 2007 12:00 am Post subject: Re: RCA TV turns off after 5-10 minutes |
| I had an RCA 36" TV from the same month and year that had exactly the same problem. After 3-4 weeks of it shutting itself off, one day it just stopped turning on and it was dead. |
Posted: Sun Jun 17, 2007 6:12 pm Post subject: Re: RCA TV turns off after 5-10 minutes |
| brianjagielski wrote: |
L14401 has bad solder connections and it probably took out the horizontal output transistor. |
