philips l01.1e
terminator2k2
PostPosted: Fri Apr 29, 2005 3:51 pm    Post subject: philips l01.1e Reply with quote
hi all just wandering if some one could help me.?? i have a philips 32pw6006, it uses the L01.1e chassis. problem is from cold the set will switch on and after 10 or so seconds , the set will switch off , but not into standby. if i keep pressing the channel up/down buttons the set will remain on and stay on, but what would cause it to shut down after 10 secs.?? i think it may be the tube.???
qbsystems
PostPosted: Sat Apr 30, 2005 9:04 am    Post subject: Re: philips l01.1e Reply with quote
This fault is cause by c2455 in the line drive replace with 105oC type as original is 85oC
PostPosted: Tue May 03, 2005 7:25 pm    Post subject: Reply with quote
hi there thanks for your reply, i changed that cap and also adjusted the a1 as per service manual with a scope to no avail... i have now got 3 sets with the same fault, 2 x 32s and 1x 28.
mark
PostPosted: Thu May 05, 2005 5:26 am    Post subject: Reply with quote
you losing hv?
i know phillips had issues with some micros on some sets that caused weird problems.
the fact that you have 3 makes me wonder tho, red flag there.
PostPosted: Thu May 05, 2005 7:27 pm    Post subject: Reply with quote
loseing hv.?? what do you mean by that.?? i know the a10 chassis suffers from micro probs, but ive neever changed one on this chassis. its also displaying fault code 11 in service mode, wich says check the rgb output, so ive ordered a couple to see what difference that makes. i still think it might be duff tubes though as its only faulty from cold and there are no voltage variations or picture/sound faults before the sets go off.
Eam
PostPosted: Mon May 09, 2005 7:58 pm    Post subject: L01 Reply with quote
Hi
I have had 2 l01s with this problem, sorry to say both sets the CRT was the cause one boosted clear the other did not.
Regards Eam
