dbbogdanovic
Posted: Sat Mar 13, 2010 12:01 am Post subject: acer lcd monitor "al1916wAS" problem |
i have this lcd monitor. monitor is dead, no stand by.
and i need a service manual for this model.
please help me.
thank you |
Posted: Wed Mar 17, 2010 4:32 pm Post subject: |
I have one of these monitors and it had several capacitors blown in the power supply circuit. Replacing them all repaired my set.
Re-search in google, tells me this is a common problem, and when the caps go they sometimes take out the F200 fuse on the back of the circuit card as well as the power mosfets for the invertor. |
minnie-me
Posted: Thu Mar 25, 2010 4:48 pm Post subject: I had a similar problem |
If the caps and supply are fine....check the voltage at the power on button. It should be around 3.3 volts. Goes to gnd when pressed. If the open switch voltage is way below this, check the 3.3 volt regulator on the input board...should be 3.3 volts when the unit is plugged in. If not, change it. |
Christie DWU1052 DHD1052 SM CHRISTIE • V2000 Grundig • tk4a55d 100827 Toshiba • 425A Service and Operating Agilent • mitsubishi ct-25m5bt MITSUBISHI • SAMSUNG+CHASSIS+WZ74++model+WS2820PP Sam • MC994A plt LG • Monitor_10.0_Release_Notes_Jul82 apple • Decca 99 DECCA (GB) • EE1007-de Philips •
