DVD player - "no disk" message
Goto page 1, 2  Next
mhuk
PostPosted: Tue May 16, 2006 4:17 pm    Post subject: DVD player - "no disk" message Reply with quote
When I insert a dvd into my Panasonic s75 the tray stops before it closes.
If I push it shut I get a "no disk" message.
Is this easily repairable or is it a bin job?
Thanks Smile
PostPosted: Tue May 16, 2006 5:16 pm    Post subject: Reply with quote
AFTER INSERTING THE DISC SEE IF IT ROTATES, IF IT DOES NOT GIVE IT A NUDGE TO SEE IF IT STARTS TO ROTATE, IF IT THEN ROTATES THE SPINDLE MOTOR IS PROBABLY U/S, CHECK ITS RESISTANCE TO BE SURE, IT SHOULD BE BETWEEN 12R & 14R AT ALL POINTS OF ROTATION.
mhuk
PostPosted: Tue May 16, 2006 5:21 pm    Post subject: Reply with quote
Thanks for the reply. How do I nudge it if the tray is closed?
PostPosted: Tue May 16, 2006 5:42 pm    Post subject: Reply with quote
TAKE THE LID OFF THE SET, WHEN THE TRAY CLOSES YOU WILL BE ABLE TO SEE THE DISC IN THE MECH, I USUALLY USE A COTTON BUD TO GIVE IT A START IN THE CLOCKWISE DIRECTION.
mhuk
PostPosted: Tue May 16, 2006 5:46 pm    Post subject: Reply with quote
Doh! I should have thought of that- I'll have a go and see what happens Smile
mhuk
PostPosted: Tue May 16, 2006 6:43 pm    Post subject: Reply with quote
When I press the "close" button the tray starts to close then stops. The little piston that appears to close the tray moves a few times then stops. If I push the tray closed the disk just sits in the tray- the "spindle" appears not to move up to the disk (as I guess it thinks the tray is still open). So no it doesn't move if I touch the dvd.
Ideas?
PostPosted: Tue May 16, 2006 8:11 pm    Post subject: Reply with quote
MECHANICAL ALIGNMENT IS POSSIBLY INCORRECT, EVERYTHING ON THIS MODEL IS DRIVEN FROM THE SLED MOTOR, IF TRAY IS OUT BY 1 TOOTH IT WILL FAIL TO LOAD CORRECTLY. NOT AN EASY MECH TO RESET, SEND ME YOUR EMAIL ADDRESS AND I WILL SEND YOU THE INSTUCTIONS
mhuk
PostPosted: Tue May 16, 2006 8:25 pm    Post subject: Reply with quote
Thanks for your help, PM sent Smile
mhuk
PostPosted: Wed May 17, 2006 3:54 am    Post subject: Reply with quote
It opens correctly, just stops on the close. Which section is for realigning the tray?
Thanks again Smile
PostPosted: Wed May 17, 2006 4:13 pm    Post subject: Reply with quote
click on navigator then section 9
Goto page 1, 2  Next
Page 1 of 2
